I have changed the 'position' of my model to reflect the actual RL of my project, however when I created my topography, the shared coordinates had not been adjusted. So now when I go to edit my topography it shows the RL's relative to my floor plan as if it were '0' not 66900.
Should I have created the topography after I adjusted the shared coord's?
Is there a simple way of fixing this?
Cheers,
Raoul
Solved by ryan.duell. Go to Solution.
When adding a toposurface the elevation points always reference absolute 0’-0”. Unfortunately they do not take shared positioning [such as specify coordinates at a point \ relocate project] into account regardless of whether added before or after the change occurs.
Video Example: http://screencast.com/t/jTAzMXgYL
This is a current wishlist item, which if you would like to also provide feedback I have provided the direct link below:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Thank you,
