Hello All:
I'm using Revit 2014 & having a problem with railings. I am trying to extend the top rail past the end of the stair at the lower level & want a 16" extension of the top rail, & loop around back. The problem I am having is that I not able to edit the top rail. Now, I'm a novice, but when I highlight (hover over) the railing assembly & then use the tab key, it will not cycle between the railing & balusters, therefore I cannot edit the top rail (Modify | Top Rails). Is there some setting for the tab key to cycle or am I not using the procedure correctly? My cursor is over the railing....
Tab key (advances through options or the selection of nearby or connected elements) - what am I missing?
Thanks in advance,
Jeff
Solved by Jleibold. Go to Solution.
To all;
I know it was a dumb question, but....I installed the 2015 version & it works now, 2014 nope....
Thx
Jeff
