Toggle Mullion Join
3 REPLIES 3
2683 Views, 3 Replies
Toggle Mullion Join
When working with mullions, there is a "Toggle mullion join" at the end of each mullion and you have to pick each one individually to toggle. Is there any way to pick a group of mullions and have them all toggle at once?
Tim Ulrich
Firmwide CAD Manager
HOK
3 REPLIES 3
Jason.Smith.SG
**BUMP**
9 years later, still need a solution for this ...Anyone out there in Autodesk land care?
Doing this individually wastes hours of time on large projects
Alfredo_Medina
Wow, what a bump! 9 years!
You cannot select multiple mullions to use the toggle, but you can prevent excessive future changes if you predefine the preferred joint condition in advance, in the curtain wall's type properties:
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
JoAnn_Hogan
Ok so this is the first time I saw this post and there is actually a solution:
Select your mullion > Right Click > Select Mullions > and there are many different options for example "On Gridline" > Then select the "Make Continuous" in the Ribbon.
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
