I created a new title block with the required labels as a .rfa family file, all works well while in the family, but when I create a new sheet in my project, I'm unable to edit any of the lables...even if I make the changes in the family, they don't come into the project...what am I doing wrong?
many thanks
I have included a technical solution below which covers the next steps:
Using shared parameters for a title block in a project
Thank you,
Thanks for your help,
I can now edit some parameters when I create a new sheet within my project, but some of the others are still not editable.
Ie. the Issue field (bottom right hand corner) also the 'Client' field, when I click on it, I get 'Owner' and I can't edit it...
Any ideas?
Many thanks
Can you verify if you are able to change any of the fields under Manage > Project Information?
Image Example: http://screencast.com/t/cK3QxRq36
Make sure this workset is editable out under Collaborate > Worksets > Project Standards > Project Info.
Thank you,
