Thanks David, but I didn't describe my question well, I meant how I can
control the text size in the temporary dimensions? I have one computer in
which one the texts of the temporary dimensions are too small.
They seem to be control by a zoom factor of the display, and work well in
the others computers, but in this one happens this problem and I could'nt
find where Revit stores this variable.
Thanks again, you are very kind, if you or any one else knows the answer
I'll be very grateful.
OH.
escribió en el mensaje
news:4991706@discussion.autodesk.com...
Click on Settings - Temporary Dimensions. From here you can change where
the dimension is calling itself. You can also double-click on the dimension
and type in the desired to modify size. Hope this is the answer to the
question.
