Revit Architecture
Active Contributor
rock9
Message 1 of 8 (1,470 Views)
Templates and families missing
1470 Views, 7 Replies
07-30-2012 12:07 AM
I recently got revit 2012. It installed fine, however I see no templates or revit family in the following folder
C:\ProgramData\Autodesk\RAC 2012
How should I get the families and templates for revit?
parveen.revit
Message 2 of 8 (1,462 Views)
Re: Templates and families missing
07-30-2012 04:07 AM in reply to: rock9
it you have the facility to copy and paste it from any other computer, do it.
otherwise you can repare your installation.
Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
Employee
Joe.Charpentier
Message 3 of 8 (1,457 Views)
07-30-2012 05:19 AM in reply to: rock9
For r2012 and r2013, content is not available on the website as it was in earlier releases.
You need to get the content through the installer.
Run the "repair" installer: Programs and Features>Autodesk Revit 2013>Uninstall/Change
In the Installer dialog, choose "Add or Remove Features", then choose the content packs you would like to install.
Joe
Active Contributor
rock9
Message 4 of 8 (1,432 Views)
08-02-2012 03:00 AM in reply to: Joe.Charpentier
I tried repair but couldn't get my families, I reinstalled everything, but still cannot get the template files and family files. I copied pasted my old revit architecture 2009 template and family files. Does revit 2012 has new families?
parveen.revit
Message 5 of 8 (1,418 Views)
08-03-2012 12:15 AM in reply to: rock9
I hope the copy and paste formula worked well.
Issue with 2009 families would be that your 2012 version will always upgrade them while loading into project or opening those families.
it's better that you copy these elements from any other computer which has 2012 version installed (any other colleague or friends's computer) and paste into your machine.
yes, 2012 has new families.
Valued Contributor
Message 6 of 8 (1,393 Views)
08-05-2012 07:12 AM in reply to: parveen.revit
Yeah, thats happened to me, and this is what I did...
Go to Control Panel, Unistall a Program, select AutoDesk Revit 2012, click "Unistall / Change", and when the AutoDesk Windows comes up, select "Add or Remove Features. Then check mark under Select Contect, then click Next....
Valued Contributor
Message 7 of 8 (1,390 Views)
08-05-2012 07:16 AM in reply to: jdiaz
You also can go to Autodesk SEEK.com and download all family you like.
Active Contributor
rock9
Message 8 of 8 (1,284 Views)
08-25-2012 12:16 AM in reply to: jdiaz
i went to this website, but there i would have to download it one by one. can i get bulk download anywhere?
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
