TWO DIFFERENT TAGS FOR WINDOWS
2 REPLIES 2
655 Views, 2 Replies
Hi:
Is it possible to have two different tags for windows? In some I'd want to see the description, and in others only the mark. It seems that I can only load one tag for windows at the time?
Thank you!!!
Silvia
Tags (2)
2 REPLIES 2
scott_d_davis
use the same tag with two Types in it.  One Type will show the Mark, and the other Type will show the description.  Place the tag, then switch it using the type selector.  You will have to edit the window tag to add the descriptor lable, and set up the visibility for the Types.
Scott D Davis
Sr AEC Technical Specialist
in reply to: scott_d_davis
Thank you!!!
It took a while to discover how to hide each label, but at the end I did it!!!
Silvia
