System requirements for work sharing
2 REPLIES 2
haydenwse
278 Views, 2 Replies
Using work sharing on two computers in the same office, what is the minimum stuff required to use the work-sharing in Rivet?  Do I need to have a dedicated server or can I just share the central file on windows 7 work-groups?
2 REPLIES 2
LisaDrago
in reply to: haydenwse
You can host the model anywhere - both computers that need to access it need to be able to see it and have read/write access to it.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
haydenwse
I hadn't used the network address when opening the file from the computer that has storing the central file.  Works as it should when you do that.
