Show only
Search instead for
Is there any way to separate a sweep into all its adjoining pieces? I really want to get all the pieces and their miter angles in order to dimension properly, in order to make an assemble manual.
You can select just the sweep and create an assembly out of it. Then you could make assembly views from that whihc might help in what you are trying to do by at least isolating the sweep. It does not allow you to select individual segments of the sweep.
Jeff Hanson Principal Content Experience Designer Revit Help |
