As per a previous post, I was advised to cut and create a separate slab should I want to show a surface pattern on ground.
So why is the toilet still showing beneath?
I think the problem resides in the object Family . Probably the Masking Region is missing ..
Try this:
It appears the Masking Region is present and visible on all layers?
Constantin I just started a new project, created a floor with a surface pattern, and added the component. The toilet component showed correctly.
Looks like something else is causing it! Could it be Phasing?
in case you used a Color Scheme ...check if in Properties > Color Scheme Location > is Background not Foreground
