Hi, as a complement to a solar study, is it possible in Revit 2014 to show sunlight reflection from a swimming pool surface onto nearby walls/ceilings?
My water is a floor component with swimming pool material - I can't find anywhere to adjust reflectivity for rendering
- Mick
Solved by constantin.stroescu. Go to Solution.
As I know even these refeection parameters can be encreased from Render Quality settings, you will not can obtain a desired result in Revit. I recomand you to use "Caustics"of Mental Ray in 3ds Max Design.....see a demo presentation here:http://www.dmmultimedia.com/3dtips_13.htm
Constantin Stroescu
thanks for the reply... I don't have access to that program unfortunately, but that demo was exactly the effect I was envisaging.
Regards
- Mick
