Revit Architecture
danepower
Message 1 of 11 (179 Views)
Sun Study - Inside
179 Views, 10 Replies
01-10-2008 09:05 PM
I need to conduct a sun study of a living room. The obvious solution is to turn the roof off, however this does not give an accurate represntation. I need the roof to be included in the study, but not visible.
I thought this was a view range issue, but cant get it to work.
Any suggestions?
Thanks, Dane.
Distinguished Contributor
melarch
Message 2 of 11 (179 Views)
Re: Sun Study - Inside
01-11-2008 03:06 AM in reply to: danepower
Use a camera inside the space or a section box..
Mel Persin, AIA
AEC Technology Consultant
Technology to Visualize and Realize Solutions
Modeling the Future/Drafting the Past
danepower
Message 3 of 11 (179 Views)
01-13-2008 08:49 PM in reply to: danepower
Mel,
Thank you for your reply. I cannot however attain the desired result using these methods.
Camera inside the space only gives me a perspective within that bounded room. I am actually trying toachieve a full floor plan.
I cannot get a section to work in the plane of the floor plan. Is this done differently to generating a normal section?
Thanks again.
Regards, Dane.
melarch
Message 4 of 11 (179 Views)
01-14-2008 04:02 AM in reply to: danepower
Have you tried selecting the windows or openings using the Daylights tool on the Rendering tab of the Design bar to let light come through into your interior. This should produce shadows in the interior from the windows. Also run radiosity solution for calculating both exterior and interior lighting.
Mel Persin, AIA
melarch
Message 5 of 11 (179 Views)
01-14-2008 04:55 AM in reply to: danepower
I should ask if you are just trying to get a black and white shadow study or a rendered shadow study. Because the Advanced Modeling Shadow only does a shaded or black and white (hidden line) shadow study. To get a rendered shadow study you will have to reset your scene for location and date/time to create a number of renderings and save the renderings to jpg or some other file format, then take all of teh jpg files and place them into an AVI file. For this you will need some video editing software. Or you could use VIZ or 3DMax to to the same.
Mel Persin, AIA
danepower
Message 6 of 11 (179 Views)
01-14-2008 08:10 PM in reply to: danepower
Mel,
I am looking to get a black and white / hidden line shadow study, for functional purposes only. Basically i want a floor plan with shadows as you would see them in real time (ie. not without a roof!!!)
Thank you again for all repsonses,
Dane.
melarch
Message 7 of 11 (179 Views)
01-15-2008 05:29 AM in reply to: danepower
Use a section box and set the roof to be t
melarch
Message 8 of 11 (179 Views)
01-15-2008 05:35 AM in reply to: danepower
Sorry postd the reply, but it did not work out for what you want. I am not sure you can get a sun study of floor plan interior view that shows shadows and light on the interior. The moment you make a component as a roof, invisible, you ahve removed that element from acting on the light source for shadows. It would appear that the shadow and sun studies tools were not designed to accommadate what you are trying to accomplish. Time for a wish to be submitted.
Mel Persin, AIA
Member
toni
Message 9 of 11 (179 Views)
08-04-2008 10:00 AM in reply to: danepower
I am trying to render interior solar 1 day studies, and am not getting any shadows showing in the movie, what do I need to do to fix this? I was able to do the studies with no problem in 3D view.
For the interior studies, I am using section views.
melarch
Message 10 of 11 (179 Views)
08-04-2008 10:32 AM in reply to: danepower
Only 3D views can be used for rendered or shadow day or year studies. To use a floor plan, create a 3D view and in the view properties turn on (check) Section box, then use the section box top plane control arrows to cut into the 3D model to the floor you want to shadow. Place the view into a top view orientation
You can also set the 3D view with the section box to match another view (see View menu Orientation, select view).
Make sure the surface plane is set to the level you want so th shadows fall on the right level.
Mel Persin, AIA
Modeling for the Future/Drafting in the Present/Building on the Past
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
