Steel Columns will not show up on Floor Plans
6 REPLIES 6
B00548410
2045 Views, 6 Replies
Hiya I have inserted my steel columns on my ground floor plans but when I go to view them they are not showing up on floor plans or the 3D view.
Can anyone help me with this problem.
Victoria
6 REPLIES 6
try these:
  • verify in VGO > Model Categories > Structural Columns must be checked
  • pay attention to choose height not depth when placing column....otherwise the column will be placed out of View Range
  • control the View Range values
  • verify the Detail Level . If Coarse ,then it will be shown simplified as a line....
Constantin Stroescu
BIM Manager AGD
Your Name
B00548410
in reply to: B00548410
Thank you I had the column set as depth.
Thanks for your help
Victoria
when doing the beams it does the same but it doesnt have any options to change?
  • Suppose the beam is placed at Level 1 with Z Justification at Top.
  • That means that the beam is under Level 1 and it will not be seen unless we change the View Range at a negative value (slightly under 0,00 )
  • If Z Justification is at Bottom or even Center, the beam will be seen even if we not change the View Range ...
By default , Beams are with Z Justification at Top , this explains why you have to make changes in View Range in order to see it
Constantin Stroescu
BIM Manager AGD
Your Name
B00548410
Thats great, thank you for your help:-)
Thank you very much!
