Show only
Search instead for
No, simple as that... Maybe it is not a BIM priority 😞 wrote in message news:5694354@discussion.autodesk.com...
Any easy way of numbering stair threads in plan and section, as opposed to
the autocad way?
ta
Mick
that will give you a total number of stairs. (You can customize you're own)
If you are looking for numbering each of the stairs theres no automatic way
I've been considering a 2-pick annotation or detail item that would autocalc
the treads or risers based on an input tread length/riser height. Not quite
as automatic as a tag, but still better than manual input.
-MJ
wrote in message news:5695648@discussion.autodesk.com...
