Stair Shape
4 REPLIES 4
KarzanCM
818 Views, 4 Replies
Stair Shape
How can I extend Tread below the riser, I have attached a picture for explanation , the Autocad illustration is what I want, The Revit three D model is what I have, What Should I change to achieve the AutoCAD illustration.
4 REPLIES 4
in reply to: KarzanCM
You can change it to a "monolitic" stair to get that effect.
cheers
KarzanCM
Thanks for your reply, I already tried that, but I don't get that result. I get the same using underside of winder as smooth and stepped as well.
 thanks
mike
In the stair proerties dialogue box there is an option to "extend tread under riser" which may help.  Or could you set the riser thickness to be 0.18 ?
KarzanCM
in reply to: mike
Thanks Mike,
I set riser thickness to 0.18 and it worked , that is how I wanted it.
