I currently have a situation in white my stair handrail mid post wont connect to my stair stringer. I have a C10 stair stringer and am using a modified typer square handrail system I have made. I am sure there is a setting or preference I have missed that is causing this. I have attached an image for reference.
ALSO in the image you can see the top rail does not fully attach to the end post. It sits in the middle somehow. AND that end post sits halfway off the stringer.
I solved my own problem...
For the first situation, I realized that the base offset was set to 2" from a previous stair type. oops.
For the second situation I changed the ballister space option until the ballister moved to the correct spot. I still do not understand how this ballister space option works, I just played with it until it was right.
