i've only been able to do this with different views.
what do you mean by "manage annotations, and view properties between two
separate views"?
set up 1 complete then do your duplicate with detailing for the other, crop
em and your done. (match line can be a family that shows up in both views)
I haven't played with scope boxes much (only read about) but this may be an
option as well.
Brian Earsley
www.arete3.com
708.342.1250 x.225
New to DWF? Check it out!
http://www.arete3.com/services/communication.html
select "ARCHITECTURE" - "File Formats"
wrote in message news:5392442@discussion.autodesk.com...
Is there a way to spread a view across multiple sheets? For instance I want
to plot at a certain scale, but at that scale my building is to big to fit
on the paper. So I want to print a plan across two sheets with a match line.
However, I'd rather not have to mangage annotations, and view properties
between two seperate views.
Message was edited by: aireq
