Spot elevation doesn’t’ take the correct measurement,
2 REPLIES 2
JamaL9722060
1133 Views, 2 Replies
I tried to add the “spot elevation” for the stair plan but sounds not to take the correct value.
What might be the reason?
Thank you
Best
Jamal
Jamal Numan
2 REPLIES 2
CoreyDaun
in reply to: JamaL9722060
There are a couple of parameters that control the reported elevation (see image), have you checked these settings?
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
JamaL9722060
in reply to: CoreyDaun
Many thanks for the help CADastrophe. It does work.
Your screenshot is a good “road map” for the solution
Best
Jamal
Jamal Numan
