When splitting a schedule, the title of the schedule shows up above each of the columns created. Is there a way of having it so that when you slit a schedule in multiple columns, the title centeres over the entire view and shows itself only once instead of once over each column?
Solved by constantin.stroescu. Go to Solution.
If you choose in schedule from Appearance to uncheck Show Title then the title will not appear at all .
Then, on sheet you can place a text with the title you want .....
Constantin Stroescu
Manually doing something that Revit should let you do automatically- another example of Autodesk shooting itself in the foot. Completely unacceptable and another opportunity for my Principal to complain to me about the "industry-standard software not aligning with established graphic standards."
