Spiral Ramp
2 REPLIES 2
613 Views, 2 Replies
Spiral Ramp
A friend is using Revit (i use adt) and he was showing me a ramp he is trying to draw - it is based on a circle in plan and rises up to a point and the middle of the 1/2 circle then back down again. He was picking th etwo sides (part circles in plan) then the start and finish (midpoint high end) but revit keeps saying could not generate ramp - he would appreciate any help Ken
2 REPLIES 2
jayre
I have a similar problem. We have a retaining wall in an 'S' shape. I would like to show a constant slope along the top through the 'S'. This seem to require a blend through a path (as a voild). What is the best approach?
I have no solution for the ramp.. it is unclear to me what your friend's tring to make.. but the retainingwall is quite easy: Just draw the S-shaped wall, draw a Ref.Plane with the angle you need in Elevation or Section, attach top of wall to the Ref.Plane. "jayre" schreef in bericht news:30937089.1086606339655.JavaMail.jive@jiveforum1.autodesk.com... > I have a similar problem. We have a retaining wall in an 'S' shape. I would like to show a constant slope along the top through the 'S'. This seem to require a blend through a path (as a voild). What is the best approach?
