Solid imported from ACAD
4 REPLIES 4
198 Views, 4 Replies
I created a large boulder using 3d faces & imported it OK into Revit. But it won't let me assign a material so it ends up looking very plain. Ideas?
4 REPLIES 4
create a generic family, import the 3D into the family, then assign materials. Place the family in a project. "Glenn Nelson" wrote in message news:418ec7b9$1_1@newsprd01... > I created a large boulder using 3d faces & imported it OK into Revit. But it > won't let me assign a material so it ends up looking very plain. Ideas? > >
That's what I did up front & there isn't a property value in the 3D import that will accept a material designation. I've taken the liberty to attach my cheesy rock. "Scott Davis" wrote in message news:418ecfce$1_2@newsprd01... create a generic family, import the 3D into the family, then assign materials. Place the family in a project. "Glenn Nelson" wrote in message news:418ec7b9$1_1@newsprd01... > I created a large boulder using 3d faces & imported it OK into Revit. But it > won't let me assign a material so it ends up looking very plain. Ideas? > >
Open your family and in the family editor go to "setings" - "materials", and there you have a "render material 127-79-63". This is the material assigned to your rock. Just rename it, change texture......etc..whatever you want , and close the dialog box "ok".
Regards
Miguel Miranda
The material is assigned by layer, check your object styles under imports and if you know what layer your rock is on, just change that layers materials.
