When I export my solor study I am having a hard time controlling the size of the building in the frame. Also, and the building seems to move when the movie is played. Is the anyway to zoom in on the building and keep the **** thing from moving around? I've attached my AVI.
James LeVieux
I was able to reproduce a similar scenario in my testing. I have followed up with the development team for some verification and will update this thread when additional information is available. Thank you.
Just to give you a heads up, in my testing this behavior was improved after applying the Web Update 2 Service Pack for Revit 2011. Are the results improved for you as well?
Links are below if needed:
Thanks again,
Hi guys
we have the same problem though the service pack 2 is installed.
Any further tips?
Alessio Boco
SWECO Architects AB
Thank you for your patience during this review process. To keep you posted, the development team did reproduce and isolate what is going on with this issue.
In previous releases shadows could be cut off depending on the view when they passed outside the view area. This would cause unintended cropping of shadows, so a change was implemented in 2011 which resolved this. However, it appears that depending on the view in 2011, this can cause the view to “jump” around when the shadows get close to the edge of the view.
The development team has identified this issue, and will be working to resolve this behavior in a future update \ release. I do apologize for any inconvenience this has caused you for the time being.
Thank you,
I wanted to include an approach which should work around this issue for the meantime. The blog post is included below:
As always please let us know if this works around the issue, and mark this thread as solved if this is the case.
Thank you,
