I'm working on reflected ceiling plans for the first time. The office building I'm working on has 20 tenancies per floor, each with its own ceiling grid. I need to add smoke detectors, alarm speakers, motion detectors, and light fittings.
A draftsman that used to work for me has drawn the ceilings as filled regions on plan and created generic symbols such as an S in a circle for a smoke detector. This is obviously not the way things are meant to be done, but having spent 2 hours on this already I can see why she gave up and cheated: things just don't work with Revit.
I am ok with setting up the ceiling grids, which I'll proceed with while waiting for some help on my various problems below:
1. How can I change from the 3D smoke detector to a simple S in a circle?
2. How do I add a separate ceiling speaker as the alarm, being the letter A in a circle? Presumably, once I know how to do this with propper families that are linked to the ceiling, I'll be able to do other fittings as well.
3. How do I create a tag that allows me to enter the smoke detector number?
Solved by maciejwypych. Go to Solution.
@NigelParsons4560 wrote:I'm working on reflected ceiling plans for the first time. The office building I'm working on has 20 tenancies per floor, each with its own ceiling grid. I need to add smoke detectors, alarm speakers, motion detectors, and light fittings.
New>Family>Metric Electrical Fixture ceiling based
Annotate>Symbolic line - Draw a circle & draw letter A (if you use the text on the annotation tab it won't be visible in the project)
Load into project
Same as above
New>Family>Annotations>Metric Electrical Device Tag
Create>Label
Place the label in intersection of the ref planes
In the pop-up windows select the Category Parameters you want to tag (Mark in your case) and click on the button with a green arrow Add parameter(s) to label.
Load into project.
All done 🙂
Hope this helps,
Maciej
