Snap to material
6 REPLIES 6
512 Views, 6 Replies
Snap to material
is there a way to disable snap to materials? I have a wood floor and when I try to draw a wall it will snap on every single wooden board. Gets really anoying.
Thanks.
Maxime Sanschagrin
6 REPLIES 6
Create a duplicate view that does not get put on a sheet, and turn off the floor surface pattern in that view.
Nice workaround. So I guess there's no way real way to turn them of for mats...
But that will do the trick anyway ;o)
Thanks a lot for the tip.
Maxime
You could temporarily hide the floor in that view, then turn it back on again.
Scott Womack
or toggle SO (snaps off) as a keyboard shorcut, which temporarily turns off
snaps for the next pick.
wrote in message news:5918991@discussion.autodesk.com...
again.
Scott Womack
Thanks guys!
anthonyEFVMT
You can also change the fill pattern to 'drafting' as opposed to 'model'. This will stop snapping to the lines of the hatch pattern.
