It seems that the current version of Revit still does not has the Snap To Midpoint Between Two Points, is that correct?
This is a VERY USEFULL tool and really needs to be addressed and added by AutoDesk!! Please let us know if this is in the future plan!! Thanks!
I'm not sure I understand your instructions... also, why hasn't AutoDesk just added this popularly requested feature to Revit? I use it ALL THE TIME in AutoCAD.
See screencast below for the instruction. Are you asking me why or it is just an expression?
This useful snap missing in Revit is used a lot when you do reflected ceiling plans and need to locate the lighting and other ceiling elements, among other of its possible many uses. This is another of these snaps that eliminate some steps.
It seems that Revit need an "evangelist" to publicly identify these issues like Lynn Allen used to do with AutoCAD.
If you really think it is that useful, the appropriate place for this these posts is over here:
https://forums.autodesk.com/t5/revit-ideas/idb-p/302
