I have just received the following report. Maybe you face similar issues, let me share the question and a possible solution with you:
Wall sweep can only be performed vertically or horizontally. I want a wall sweep with an angle to horizontal. This should be possible, but by simply trying to rotate, it jumps back to horizontal position. What do I do...?
A possible way to add a "slanted" profile to a wall is to create the profile as a face based component. You could use the template "Metric Generic Model face based.rft" for creating the profile.
Please see a screenshot about it.
As alternative you may model the profile as in-place component.
