Sheets are not previewed nor printed,
2 REPLIES 2
JamaL9722060
380 Views, 2 Replies
In the attached screenshots, I tried to preview and print the sheets but I got nothing!
What might be the issue here?
Thank you
Best
Jamal
Jamal Numan
2 REPLIES 2
CoreyDaun
in reply to: JamaL9722060
Print Preview uses the Print Setup configuration that was last used, which does not appear to be appropriate for a View in this case. Go to Print » "Print Setup..." and configure the settings to accommodate the Views. Now your Print Preview should use these Settings.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
JamaL9722060
in reply to: CoreyDaun
Many thanks Corey for the help,
Sorry! I got my mistake! I have edited the title block family where a line is drawn at a distance (screenshot is attached) and this is why the drawing is not shown up in the sheet (title block). I erased that line and all works fine now (attached).
The mistake was in the size of the title block after being edited!
Best
Jamal
Jamal Numan
