Sheets are not previewed nor printed,
In the attached screenshots, I tried to preview and print the sheets but I got nothing!
What might be the issue here?
Thank you
Best
Jamal
Print Preview uses the Print Setup configuration that was last used, which does not appear to be appropriate for a View in this case. Go to Print » "Print Setup..." and configure the settings to accommodate the Views. Now your Print Preview should use these Settings.
Many thanks Corey for the help,
Sorry! I got my mistake! I have edited the title block family where a line is drawn at a distance (screenshot is attached) and this is why the drawing is not shown up in the sheet (title block). I erased that line and all works fine now (attached).
The mistake was in the size of the title block after being edited!
Best
Jamal
