I am assembling my various views onto sheets.
My floor plan located in the sheet view has grips for what I assume is for the visible area desired in sheets. I am not sure how or what I did to make these grips accessible. I opened a new drawing and it does not seem to be in a default drawing. When I open any of the other view foundation, roof, roof framing ect. I do not see the grips.
When in sheet view “floor plan” this area seems to have a box around it. See attached drawing.
In the foundation view plan there are no grips and no box around it in the sheet view until you highlight it and I can not change sheet view. See attached.
What I am trying do is fit the various views on to a sheet. However they overlap each other. Question is how to change viewport size in sheet view so I can fit a number of different views onto one sheet. How do I eliminate the box around the floor plan in sheet view?
I guess I am use to the Autoarchitects view ports. Perhaps it does not work that way in Rivit.
It looks like you have the viewport active. I say this due to the title block being greyed out.
The other reason I have found which causes the box around the view is if Crop Region Visible is selected.
