Melarch,
How can the copy/monitor function work best when transferring files between
consultants?
In my situation, I send my arch models to the structural every so often, and
they send me theirs. So far, when they send me a new one (once per month or
two), I change the name of it and my arch file automatically picks it up as
the linked file. As my deadlines get closer, I can't do this anymore as it
deletes all my dimensions associated with the structural file. So my
alternative, is to adjust my structural file to match any changes taken
place in the next file I receive. (Just to clear this up, my building is
pretty large, and is therefore split up into three arch files and 1
structural, all inter-linked into eachother, and the structural consultants
are a different firm 1,000 miles away) I don't think the copy/monitor works
if structural is always sending me a new copy of their file.
Over the course of this project, I've managed to work out a lot of the kinks
in this process, but of course its not perfect, so I'm trying to pick your
brain for ideas for future projects.
Jay
wrote in message news:5049803@discussion.autodesk.com...
When Autodesk developed the Revit Structural program the added the following
feature and tool. The feature and tool (see tool button to left of Join
Roofs) is copy/monitor. The copy monitor feature allows you to monitor a
single project file that is work-shared between multiple users using
Autodesk Revit Building or Structure and is designed to report changes.
Or you can have a Revit Building project file and the Structural consultant
can work on his own Autodesk Revit Structural project file. You Import/Link
each others project files to your project file. You exchange updated
project files as necessary and in-turn review any changes. The copy/monitor
checks each others project files for changes and lets you review the
changes.
Works quite well. Of course you can always work through an FTP site. But
the recommended way to manage data between Revit Building and Structural is
by Import/Linking. That way each professional/discipline can work
independently on there project file data, without diminishing LAN or workset
performance or relying on the Internet for coordination. Also, Internet
collaboration can be expensive, especially if you hadn't budgeted for the
expenditure and no one wants to share or absorb the cost. It is worth
investigating on your next project.
Mel Persin, AIA
ADT/Revit Consultant and Trainer
melarch@ameritech.net
