We are having a problem with the Shaft tool in Revit in our office, so I am trying to understand it more completely. We have pipes running inside wall assemblies. We would like to cut a hole in the wall assembly parts, floor, ceiling - everything that the pipe passes through. Is there a certain workflow or recommended way of using the Opening tools that will help us with this process?
Jessica
Solved by Alfredo_Medina. Go to Solution.
@Anonymous wrote:
The whole idea of using a shaft tool is not to cut the slab.
Then exclaim the whole idea clearly when asking the question.
