Shaft change shape
1 REPLY 1
431 Views, 1 Reply
Shaft change shape
I have in Revit 2011 made a shaft in floors for a stair, how do I change shape of shaft in plan, I don't seem to be able to select it to edit boundary.
1 REPLY 1
AJA14
Use Tab to cycle between the different elements to select your shaft and look at the status bar to know what you're selecting. You could also use window crossing and then use filter from the contextual ribbon.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
