Shadows
4 REPLIES 4
357 Views, 4 Replies
Shadows
I know I can render a color 3d view using orient but can revit cast shadows on a black & white model? If so how? I am having a brain cramp Doug
4 REPLIES 4
Only by rendering at this point. You could set your materials to be all white, so when rendered you would have basically a black and white model with shadows. SD "Doug" wrote in message news:402981b7$1_1@newsprd01... > I know I can render a color 3d view using orient but > can revit cast shadows on a black & white model? If so how? I am having a > brain cramp > > Doug > >
You could make glass-material invisible, so you get the windows as holes. Might make for a pretty nice picture. --- stefkeB --- "Scott Davis" wrote in message news:4029872e$1_1@newsprd01... > Only by rendering at this point. You could set your materials to be all > white, so when rendered you would have basically a black and white model > with shadows. > > SD > > > "Doug" wrote in message > news:402981b7$1_1@newsprd01... > > I know I can render a color 3d view using orient but > > can revit cast shadows on a black & white model? If so how? I am having > a > > brain cramp > > > > Doug > > > > > >
This would be a great addition to revit rendings! Doug "Doug" wrote in message news:402981b7$1_1@newsprd01... > I know I can render a color 3d view using orient but > can revit cast shadows on a black & white model? If so how? I am having a > brain cramp > > Doug > >
To better define shadows go to Rendering >Settings>Sun>Settings and increase the Intensity of the sun and decrease the sky intensity.
