Setting the height of the masonry stone,
I couldn’t figure out how the height of the masonry stone can be set.
For example, in the attached screenshot, I wanted the height to be 0.26 meter then how this can be done?
Thank you
Best
Jamal
stacked wall function does not please you ? for me you question seems to be a little unclear....
Your Name
Please do your own hatch pattern using http://mertens3d.com/tools/revit/2012/hatch22-2012/hatch22-2012.php. It easy to draw your desired pattern. Anders
Hi jamal,
If you're importing a custom .pat hatch, then you have two choices.
1- modify the .pat file itself to get the correct results.
2- After importing to revit, check the dimensions. If you need say 100 mm and it is 50 mm, then reimport the same .pat file and put 100/50 = 2 in the scale prompt. It will then multiply the pattern by 2.
Many thanks guys for the help,
I thought that there might be simple way to do this as all what I need is to have the same hatch built in the revit but with different height! That’s all.
I got the link below that requires using third party software to manufacture *.pat files
http://www.youtube.com/watch?v=cJAsIdCmX3Q&feature=player_embedded#!
Best
Jamal
