Revit Architecture
JamaL9722060
Message 1 of 3 (149 Views)
Selection layer edges of a particular wall,
149 Views, 2 Replies
10-02-2012 02:26 PM
It is really exhaustive when it comes to select an edge of a layer of a wall. For example, if we need to align a column in the wall in the correct space, we need to select the corresponding edge of layer of the wall (indicated in the screenshots below). It really takes time just to select this edge (hovering + TAB).
What might be the best practices for the selection?
Best
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
Employee
loboarch
Message 2 of 3 (135 Views)
Re: Selection layer edges of a particular wall,
10-03-2012 06:06 AM in reply to: JamaL9722060
You can change the preferences setting in the option bar while using the align tool to prefer "faces of core" this might get you closer to what you are after.  If the alignment point you are looking for is NOT the face of a core you will still need to us ethe tab key to get to the other faces inside the wall.
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
JamaL9722060
Message 3 of 3 (119 Views)
10-03-2012 02:18 PM in reply to: loboarch
Many thanks for the answer.
Selection with tab is very tedious sort of work! Why the edges of all layers of the wall are not candidate (have blue color) be default? This is much easier than spending more time in just selecting the target edge with tab
Firefox 20.0,
Kaspersky 2013.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
