Section line is not displayed
2 REPLIES 2
GHASEM_ARIYANI
607 Views, 2 Replies
Hi
When I exported my project from Revit to Autocad Software Section line is not displayed.
Does anybody know where is the problem?
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
2 REPLIES 2
Did you ever find an answer, as I have the same problem.
by default the Section Line is exported in Layer: A-ANNO-SYMB ( look in > Export >Options >Export Setups DWG/DXF where you can control the export parameters)
In Autocad check the Layer state...not to be frozen......
Constantin Stroescu
BIM Manager AGD
Your Name
