Screen Resolution requirements - Set in stone?
2 REPLIES 2
1115 Views, 2 Replies
So the resolution for 2012 Revit is 1,680 x 1,050 monitor with true color, according to the system requirements on the product page.
Is that a REQUIREMENT? Can I use a monitor with a smaller screen resolution?  If so, what will I be sacrificing?
Thank you so much.
2 REPLIES 2
ryan.duell
You can technically use a display with a lower resolution but it will collapse some tools and some larger menus may not display as desired.  For example, the tools may appear similar to the image below in a collapsed state or with smaller icons:
Image Example
The recommendation was the resolution the application was built around as a best starting point.
Thank you,
Ryan Duell
Nice! Thank you.  I went ahead and purchased a 21.5" monitor with a 1920 X 1080 resolution.
