Okay, so I created a demolition tag using the Generic Annotation template, and since I couldn't load a shared parameter, I simply shared a type parameter for my demolition tag #. I then created another "shared" parameter for demolition notes, which was not assigned to the label in my tag. It was then easy to load this into my project and then to create a note block that had these parameters inserted into its fields.
BUT, I still cannot schedule the linked notes in my host file!! This option is greyed out in the note block's properties window (just like it was in our keynote schedule that wouldn't work either.)
Please, what am I doing wrong? Do I HAVE to tag the demolition in the host family on top of the linked project file that actually shows the demolition? I'm guessing this is the case or else I could have multiple demolition note definitions for the same demolition tag # because of trying to schedule from the host and linked file.
Any advice would be greatly appreciated.
Thanks.
- Alex
