Schedules and alignment / Coordination
1 REPLY 1
464 Views, 1 Reply
Is there a way to format all the cells in a schedule to display equally? I
seem to be only able to tweak the columns and I have no idea if the spacing
between rows is equal or not? Also can schedules be locked on a sheet to
insure they are not moved around? Thanks!
1 REPLY 1
RevitIt
To prevent the schedule to move, use the pin tool. its top right on your screen.
As for specific dimension, note that when in the schedule view, modifying the width doesnt affect the schedule placed on a sheet.
No way i know of to set a specific width. So i suggest using detail lines to set the width of column, Adjust the schedule. Delete the lines and pin the schedule.
