Hi Guys,
I have two Buildings same Building height but different floor area. Is there anyway that i can separate the schedule and quantities of the said two Building? Bcos when i generate schedule/quantities they are always counted together.
Please see attached.
Solved by constantin.stroescu. Go to Solution.
Make two schedules and use Filter by Mass :Type
First Filter Mass 1 , then Mass 2
Constantin Stroescu
Hi Constantin,
Thank you for your prompt reply. Im a bit confused bcoz i have 3 mass type in building 1 and another 1 mass type in building 2. I followed your instruction but it seem that i can only do schedule/quantities for every mass (1 scheduled)
Is there anyway that i can do one schedule/quantities of 1 buliding that consist only 3 mass ( mass 1 , 2 , 3) and the other building 2 which another set of schedule/quantities of mass 4.
Thank you for your help.
Please find attached of some capture images.
Thank you.
add capture files
Using Fiilters and Sorting/Grouping you can obtain all sorts of schedules.
Look in the attached de capture recording I ;ve posted in Autodesk Chronicle a few minutes ago...
https://chronicle.autodesk.com/Main/Details/8e80ce6a-d222-47ea-9e59-34c86e2dd6ee
Constantin Stroescu
