It is very strange to see all the common modification tools like move, copy,
rotate etc. and not having a scale command. I can understand that most of
the times there is a way to change the size of something by making a
parameter in the family or by making a smaller one in an other file but it
is very handy to be able to change the size of a north symbol when you
insert it.
I used one of my symbols from AutoCAD and when I changed the scale from the
properties dialog box the result was strange. It was more like a move
command than a scale command. Finally I used "explode" and then "Group" but
there was still no scaling option. Is there a way to make objects scalable?
What am I doing wrong?
Dimitris
P.S. The symbol "B" I want to place means "BORRAS" the Greek word for
North.
