Saving to different programs
3 REPLIES 3
394 Views, 3 Replies
My school has Revit Architecture 2013
and can't upgrade it until this summer. Will I be able to save my file in
Revit Architecture 2013 at school and transfer it home to Revit 2013 or
2014? The real question is, will I be able to save back to Revit
Architecture 2013 from Revit 2014 or Revit 2013? Are the programs
compatible?  Thank you
3 REPLIES 3
You can open it at home in 13 or 14.....HOWEVER......Oncwe you save it to
2014, you will not be able to reopen in 2013..there are not backward saves
link acad.
HTH. Mike
Michael L. Maloney
VDC & BIM Model Coordination
mike@VirtualWorldDesigns.com
Building Design Suite Ultimate 2014
Charlotte, N.C / Fort Mill, SC.
386-931-6733
"Remembering that you are going to die is the best way I know to avoid the
trap of thinking you have something to lose. You are already naked. There is
no reason not to follow your heart."
--Steve Jobs
Thanks.  I just have one more question. So I save my file at school in Revit Architecture 2013, and I open it at home in Revit 2014.  Can I save it to the same file type as Revit Architecture 2013?  Or for the files to be compatible, do I need to have Revit 2013 at home instead of Revit 2014?  Thanks for your help.
Alisder.Brown
TanCav
You cannot open any Revit file in a previous version
If you want to work on your school model (2013) at home, i would reccommend installing 2013 at home.
If you open a Revit 2013 file in Revit 2014 and save the file, it now becomes  Revit 2014 file and can no longer be used in any previous version.
Regards
Alisder Brown
Senior BIM Coordinator
Scotland, UK
