Revit Architecture
New Member
undrake
Message 1 of 6 (717 Views)
Saving to PDF using Parallels through revit
717 Views, 5 Replies
02-14-2013 09:01 PM
How do I save a file as a PDF using revit via Parallels.  In my Auto Cad Architecture I have a dwg to PDF file but don' t see it in revit.  Help!!!!!
Valued Contributor
GPR_MN
Message 2 of 6 (685 Views)
Re: Saving to PDF using Parallels through revit
02-15-2013 01:01 PM in reply to: undrake
You'll have to download a pdf generator to basically act as a printer.
Cute PDF Writer  hasn't failed me yet
Active Contributor
dworkshop
Message 3 of 6 (668 Views)
02-16-2013 03:39 PM in reply to: GPR_MN
Are you serious? I have to download/install another program to print a PDF from Revit.
Autocad to PDf worked so well before!
Can Autodesk Design Review open/view Revit files?
Valued Mentor
AJA14
Message 4 of 6 (655 Views)
02-16-2013 11:40 PM in reply to: dworkshop
Hi. sorry about the other empty post. Actually you can print directly from Revit to PDF similar to what you would do with autocad. You do need a pdf creation program however installed on your computer. I have the abobe acrobat pro, some have the cutepdf, and so on. You can easily install one free online and use it.
You can also print to design review, and compile (similar to PDF) into one file or multiple files.
Regards.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
basilmir
Message 5 of 6 (433 Views)
09-23-2013 08:46 AM in reply to: undrake
Parallels Desktop 9 now includes a Print to PDF (Mac Desktop) printer that is added to the Virtual Windows Machine by default IF "Add all Mac printers" in Configure->Hardware->Print is selected.
When you print from Revit it saves it to the mac desktop. COOL.
New Member
mbrennan
Message 6 of 6 (185 Views)
04-09-2014 10:54 PM in reply to: basilmir
Yes basilmir but you will not be able to create a custom Architectural sheet, ie. Arch D 24x36. You are only limited to the standard paper sizes.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
