Saving in revit ( big problem)
3 REPLIES 3
390 Views, 3 Replies
hey guys, i currently use the revit architecture 2011 version, i had a prior installation of 2011 on my laptop however for some reason it could no longer detect y license so i uninstalled it, then downloaded the same version again, this time a different serial number was distrubuted. The program works fine, however whenever i attempt to open the file at my schools computer in thei 2011 version, i try to save, it states "file not saved" so i then save it under another name and it states that that "the file ect was saved in a later version of revit and cannot be retrieved in this version" how is this possible when the version i initially used is from revit 2011???
3 REPLIES 3
DarrenP
are you sure its the same version as yours?
DarrenP
yes i'm sure
ah, i figured out the issue, it was a problem with my flash drive , it's corrected now
