Revit Architecture
Active Member
Message 1 of 4 (557 Views)
Rounding up length parameters
557 Views, 3 Replies
10-16-2012 07:58 AM
Hi
I am making a Schedules for metal flashings that i have added to my project. I have not had any problems using shared parameters to get the length of my line based families and everything is working fine.
But now comes the tricky part. I need to somehow add a parameter that would roundup my real lengths to my production lengths. f.eks i have couple flashings that are 2569mm And what i would like the schedule to show is that I have couple of 3000mm flashings.
Is anyone getting me?
I have been reading about formular but havent really found the answer so i was hoping somone here could help?
Regards
Sigurjón
*Expert Elite*
CADastrophe
Message 2 of 4 (547 Views)
Re: Rounding up length parameters
10-16-2012 08:18 AM in reply to: sigurjon81
You have to do a little bit of unit manipulation with a formula, but you can force the rounding to a specific increment. Below is an example.
Parameter Name        Value          Formula
TrueLength          |  2569 mm  |  =
RoundedLength  |  3000 mm  |  =  roundup(TrueLength / 500 mm) * 500 mm
The above parameter, "RoundedLength", will return the value of "TrueLength" rounded up to the nearest 500 mm.
Welcome to the Autodesk forums, sigurjon81!
Feel free to post any questions you may have! There are many experienced users here who generously contribute their time and effort to supporting
their peers. This is an open, peer-supported forum, so feel free to contribute any useful information or experiences to any of the topics you see here.
We hope you'll stick around a while and help strengthen the value of this community!
Be sure to review the Ground Rules, visit the FAQ Forum, and use the Search feature prior to posting a question, as it's likely been asked before.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 3 of 4 (493 Views)
10-30-2012 02:03 AM in reply to: CADastrophe
Quick question.
I am using 2011 version, which doesn't have the "roundup" function. Is there any way to do that in 2011?
*Expert Elite*
CADastrophe
Message 4 of 4 (483 Views)
10-30-2012 06:01 AM in reply to: peterlyh
peterlyh wrote:
"Quick question.
I am using 2011 version, which doesn't have the "roundup" function. Is there any way to do that in 2011?"
I believe that you can. I don't currently have 2011 to test with, but this should work. You will need to add a third parameter as an Integer to force the number to round. This will also add a little extra formula work to force it to specifically round up.
IntegerLength     |  5              |  =  TrueLength / 500 mm
RoundedLength  |  3000 mm  |  =  IntegerLength * 500 mm + if(IntegerLength * 500 mm < TrueLength , 500 mm, 0 mm)
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
