Revit Architecture
Bob_Zurunkle
Message 1 of 14 (2,005 Views)
Rotation in Any Axis
2005 Views, 13 Replies
02-23-2012 09:25 AM
Is it possible to create a family that can be loaded in on any view, and rotated in any direction?
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
Alfredo_Medina
Message 2 of 14 (1,991 Views)
Re: Rotation in Any Axis
02-23-2012 01:17 PM in reply to: Bob_Zurunkle
Using multiple levels of nested families, it is possible to make an object rotate in 3 planes: x/y(plan view), y/z (righ/left views), and x/z (front/back views).
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Bob_Zurunkle
Message 3 of 14 (1,980 Views)
02-24-2012 05:16 AM in reply to: Alfredo_Medina
Do you know of a step-by-step tutorial on this?
Alfredo_Medina
Message 4 of 14 (1,943 Views)
02-25-2012 04:36 PM in reply to: Bob_Zurunkle
No, I have not seen a step-by-step tutorial about this, but I could write a blog article about it.
Bob_Zurunkle
Message 5 of 14 (1,918 Views)
02-27-2012 09:07 AM in reply to: Alfredo_Medina
That would be cool :smileyhappy: and much appreciated!
Alfredo_Medina
Message 6 of 14 (1,890 Views)
03-15-2012 01:52 PM in reply to: Bob_Zurunkle
As promised, I have written a blog article about rotation in 3 different axis:
http://planta1.com/forum/entry.php?12-Rotating-a-Revit-model-family-in-3-different-axis-by-parameter...
Bob_Zurunkle
Message 7 of 14 (1,867 Views)
03-16-2012 09:34 AM in reply to: Alfredo_Medina
Much obliged :smileyhappy:
Member
jcl4439
Message 8 of 14 (1,229 Views)
05-05-2013 10:03 AM in reply to: Bob_Zurunkle
Ridiculous, I simply want to align a modeled in place component (a turnbuckle) with a cable coming from some other turnbuckle at a different height. That blog post is ridiculous.
Alfredo_Medina
Message 9 of 14 (1,218 Views)
05-05-2013 11:38 AM in reply to: jcl4439
No, it is not. That article describes a case in which you need 3 rotations simultaneously and control those rotations by parameter. There is another article about rotating elements in generic adaptive families by points. If you just need to align an object to another, without parameters, probably that article does not apply to your particular needs.
rosskirby
Message 10 of 14 (1,207 Views)
05-05-2013 06:55 PM in reply to: jcl4439
If you're modeling something in place, why would you need to rotate it?  Why not just model it in the correct orientation in the first place?
For your given situation, though, why would it need to be rotated in more than one plane?  I assume you have two turnbuckles, one at either end of an angled tension rod, correct? Wouldn't it only need to be rotated in the XY plan (when viewed in elevation)?
What was explained in the blog post was a method for creating a family that can rotate in multiple planes.  While it's somewhat complex, especially if you're unfamiliar with the way Revit works, it's certainly not a "ridiculous" solution.  And if you want constructive feedback, I'd recommend a less antagonistic approach.
Ross Kirby
BIM Manager
Arcturis
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
