If you have a scroll mouse holding the wheel down and moving the mouse will
pan. Holding the wheel down with the Shift key held down at the same time
will rotate. There is also an Eye staring at you that if depressed will
bring up a dialog box. I switch between ADT, Acad and Revit quite abit and
sometimes I 'm not sure of which day of the week it is.
bob v
wrote in message news:4908704@discussion.autodesk.com...
I have been using ADT and I am now using Revit 7. In ADT it is very simple
to rotate a 3D drawing to see all different views, is there a way to rotate
a 3D drawing in Revit? I can't seem to figure it out.
Thank you,
Anamarie
