Revit Architecture
*Stan Lacz
Message 1 of 8 (80 Views)
Rotate .jpg in Revit
80 Views, 7 Replies
06-13-2006 01:22 PM
A .jpg file was imported into Revit but when it is rotated it becomes a
black retangle. Any solution?
*Scott Davis
Message 2 of 8 (80 Views)
Re: Rotate .jpg in Revit
06-13-2006 02:40 PM in reply to: *Stan Lacz
are you using Revit 9.0? before 9.0, you could only rotae JPGs in 90 degree
increments. 9.0 you can rotate to any angle
"Stan Lacz" wrote in message
news:5204937@discussion.autodesk.com...
*Stan Lacz
Message 3 of 8 (80 Views)
06-13-2006 06:33 PM in reply to: *Stan Lacz
Yes, before .jpg was only 90° but with Revit 9 .jpg is to be rotated any °,
but this one .jpg turns into a black retangle when rotated. Why?
"Scott Davis" wrote in message
news:5205087@discussion.autodesk.com...
*Stan Lacz
Message 4 of 8 (80 Views)
06-13-2006 07:00 PM in reply to: *Stan Lacz
Try rotating in Drafting view.
*Stan Lacz
Message 5 of 8 (80 Views)
06-13-2006 07:15 PM in reply to: *Stan Lacz
news:5205304@discussion.autodesk.com...
*J F
Message 6 of 8 (80 Views)
06-13-2006 08:16 PM in reply to: *Stan Lacz
I had this exact same problem. You need to reduce the resolution of your
.jpg file. In this case size does matter.
Joe
*Stan Lacz
Message 7 of 8 (80 Views)
06-14-2006 12:11 PM in reply to: *Stan Lacz
The solution from Autodesk subscription was to bring the .jpg file into
Revit 9 and then export it as .jpg and then import the new .jpg file,
again. Worked like majic. The original file was somehow corrupted and this
method clean it up. The new .jpg can be rotated.
"J F" wrote in message
news:5205355@discussion.autodesk.com...
Joe
*J F
Message 8 of 8 (80 Views)
06-14-2006 05:42 PM in reply to: *Stan Lacz
> Joe
That's an interesting solution. I simply made the file smaller (it was
rather huge 12Mb). I wonder if it was corrupted and reducing it
un-corrupted it, or whether it was too large a file? At least now I have
more than one solution to try if it happens again.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
