Rotate Beam about it's Axis?
3 REPLIES 3
craig
1650 Views, 3 Replies
I would like to use the double angle beam to represent the steel lintel over a garage door in a double wyithe masonry wall system.
The problem is that the Revit supplied double angle beam has the back-to-back vertical legs of the angles pointing downward and not upward as is common.
My attempts to rotate the beam on its axis 180°, to direct the back-to-back vertical legs upward, are ignored by the program.
I am unable to find any other controls and program which would allow me to represent the steel being appropriately.
Has anyone found a way to represent this?
3 REPLIES 3
in reply to: craig
What I did was to take the LL Double Angle family, & invert the beams in the family.
I posted the new family & catalog file in the Revit customer files section, if you'd like to try it.
craig
in reply to: craig
If you are referring to the Autodesk Revit customer Gallery, a search for your username found zero results.
in reply to: craig
It's in the revit.community.customer-files newsgroup "Craig Cernek" wrote in message news:5744845.1078156688566.JavaMail.javamailuser@localhost... > If you are referring to the Autodesk Revit customer Gallery, a search for your username found zero results.
