Solved by bward. Go to Solution.
Has anyone come up with a methodology to create a tag that shows the occupant load of a room without having to manually add the number? I have the schedule that generates the values and I've got it to round up to a whole number, but I cannot find a way to push this number to the tag on the plan without manually inputting the result into the parameter.
anybody ... ?
Ian Shafer
GHMA
It is my understanding that formula parameters cannot appear in tags, just like non-shared parameters cannot appear in tags. I have heard of a third party software that allows this to happen. If I can find it I will post it. Typically we provide a room schedule on the life safety plans that has the use, occupant load factor, area and occupant load for each room. It is a pain to go back and forth betweent he schedule and plans but beat manually inputing info and having the potential for something to be missed.
Well, until Autodesk decided to allow calculated values in Room tags I, with some help, created a simple add-in that will take care of this for you.
http://therevitkid.blogspot.com/2013/08/saubim-code-calculations-for-revit.html
Ho w did you remove the SF suffix from the room tag? I still want the square footage to show just not the SF suffix
